Dynamic Simulation for MAS-Based Data Acquisition and Pre-processing in Manufacturing Using V-REP - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1, 2) , (1, 2) , (1, 2)
1
2
With the advent of the Industry 4.0 movement, smart multiagent-based cyber-physical systems (CPS) are being more and more often proposed as a possible solution to tackle the requirements of intelligence, pluggability, scalability and connectivity of this paradigm. CPS have been suggested for a wide array of applications, including control, monitoring and optimization of manufacturing systems. However, there are several associated challenges in terms of validating and testing these systems due to their innate characteristics, emergent behavior, as well as the availability and cost of physical resources. Therefore, a dynamic simulation model constructed in V-REP is proposed as a way to test, validate and improve such systems, being applied to a data acquisition and pre-processing scenario as one of the key aspects of the interaction between a CPS and the shop-floor.
448071_1_En_11_Chapter.pdf (550.55 Ko) Télécharger le fichier
Dates and versions
hal-01629566 , version 1 (06-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Ricardo Silva Peres, Andre Dionisio Rocha, Jose Barata. Dynamic Simulation for MAS-Based Data Acquisition and Pre-processing in Manufacturing Using V-REP. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.125-134, ⟨10.1007/978-3-319-56077-9_11⟩. ⟨hal-01629566⟩
103 View
121 Download
Share
