Full Text Documents
46
Search
Table of Contents
Technological Innovation for Smart Systems
Luis M. Camarinha-Matos, Mafalda Parreira-Rocha, Javaneh Ramezani
Front Matter
Collaborative Networks
Supporting the Strategies Alignment Process in Collaborative Networks
Beatriz Andrés, Raul Poler
3-19
Service Personalization Requirements for Elderly Care in a Collaborative Environment
Thais Baldissera, Luis Camarinha-Matos, Cristiano Faveri
20-28
A System Dynamics and Agent-Based Approach to Model Emotions in Collaborative Networks
Filipa Ferrada, Luis Camarinha-Matos
29-43
Computational Intelligence
Efficient Fuzzy Controller to Increase Soybean Productivity
Bruno Miranda, Gian Meira, Sidney Montebeller, Edinei Legaspe, Joel Pinto, Diolino Santos Filho, Paulo Miyagi
47-54
A Hybrid Expert Decision Support System Based on Artificial Neural Networks in Process Control of Plaster Production – An Industry 4.0 Perspective
Javaneh Ramezani, Javad Jassbi
55-71
Flexibilizing Distribution Network Systems via Dynamic Reconfiguration to Support Large-Scale Integration of Variable Energy Sources Using a Genetic Algorithm
Marco Cruz, Desta Fitiwi, Sérgio Santos, João Catalão
72-80
Data Fusion of Georeferenced Events for Detection of Hazardous Areas
Sérgio Onofre, João Gomes, João Pimentão, Pedro Sousa
81-89
Systems Analysis
Student’s Attention Improvement Supported by Physiological Measurements Analysis
Andreia Artífice, Fernando Ferreira, Elsa Marcelino-Jesus, João Sarraipa, Ricardo Jardim-Gonçalves
93-102
A System for Driver Analysis Using Smartphone as Smart Sensor
Rui Vilaça, Rui Araújo
103-110
Multi-criteria Analysis and Decision Methodology for the Selection of Internet-of-Things Hardware Platforms
Edgar Silva, Ricardo Jardim-Gonçalves
111-121
Smart Manufacturing Systems
Dynamic Simulation for MAS-Based Data Acquisition and Pre-processing in Manufacturing Using V-REP
Ricardo Peres, Andre Rocha, Jose Barata
125-134
Enhancing Dependability and Security of Cyber-Physical Production Systems
Hessamedin Bayanifar, Hermann Kühnle
135-143
Features Extraction from CAD as a Basis for Assembly Process Planning
Jan Wikander, Baha Hasan
144-153
Safety Active Barriers Considering Different Scenarios of Faults in Modern Production Systems
Jeferson Souza, Diolino Santos Fo, Reinaldo Squillante Jr., Fabrício Junqueira, Paulo Miyagi, Jose Silva
154-164
Smart Sensorial Systems
Image Analysis as a Tool to Age Estimations in Fishes: An Approach Using Blue Whiting on ImageJ
Patrícia Gonçalves, Vitor Silva, Alberto Murta, António Melo, Henrique Cabral
167-174
Signal Processing Techniques for Accurate Screening of Wrist Fractures
Ridita Ali, Lyuba Alboul, Amaka Offiah
175-182
TRACEO3D Ray Tracing Model for Underwater Noise Predictions
Rogério Calazan, Orlando Rodríguez
183-190
Feature Transformation Based on Stacked Sparse Autoencoders for Sleep Stage Classification
Shirin Najdi, Ali Gharbali, José Fonseca
191-200
Embedded and Real Time Systems
Quality Evaluation Strategies for Approximate Computing in Embedded Systems
Olaf Neugebauer, Peter Marwedel, Roland Kühn, Michael Engel
203-210
Configurable Reprogramming Methodology for Embedded Low-Power Devices
Ondrej Kachman, Marcel Balaz
211-219
Upper Bounds Prediction of the Execution Time of Programs Running on ARM Cortex-A Systems
Irina Fedotova, Bernd Krause, Eduard Siemens
220-229
Energy: Management
Assessment of Ancillary Service Demand Response and Time of Use in a Market-Based Power System Through a Stochastic Security Constrained Unit Commitment
Saber Talari, Miadreza Shafie-Khah, Neda Hajibandeh, João Catalão
233-241
Self-scheduling of Wind-Thermal Systems Using a Stochastic MILP Approach
Rui Laia, Isaias Gomes, Hugo Pousinho, Rui Melício, Victor Mendes
242-250
Impact of Distributed Generation on the Thermal Ageing of Low Voltage Distribution Cables
Gergely Csányi, Zoltán Tamus, Árpád Varga
251-258
A Hybrid Anti-islanding Method for Inverter-Based Distributed Generation
Ebrahim Rokrok, Miadreza Shafie-Khah, Hamid Karshenas, Esmail Rokrok, João Catalão
259-266
Energy: Optimization
A New DG Planning Approach to Maximize Renewable - Based DG Penetration Level and Minimize Annual Loss
Soroush Najafi, Miadreza Shafie-Khah, Neda Hajibandeh, Gerardo Osório, João Catalão
269-276
Stochastic Optimization for the Daily Joint Operation of Wind/PV and Energy Storage
Isaías Gomes, Hugo Pousinho, Rui Melício, Vitor Mendes
277-286
The Impacts of Demand Response on the Efficiency of Energy Markets in the Presence of Wind Farms
Neda Hajibandeh, Miadreza Shafie-Khah, Saber Talari, João Catalão
287-296
Implementing an Integer Linear Approach to Multi-objective Phasor Measurement Unit Placement
Amir Baharvandi, Miadreza Shafie-Khah, Saber Talari, João Catalão
297-304
Distributed Infrastructure
RELOAD/CoAP P2P Overlays for Network Coding Based Constrained Environments
Eman Al-Hawri, Noelia Correia, Alvaro Barradas
307-315
PVInGrid: A Distributed Infrastructure for Evaluating the Integration of Photovoltaic Systems in Smart Grid
Lorenzo Bottaccioli, Enrico Macii, Edoardo Patti, Abouzar Estebsari, Enrico Pons, Andrea Acquaviva
316-324
MAP Estimator for Target Tracking in Wireless Sensor Networks for Unknown Transmit Power
Slavisa Tomic, Marko Beko, Rui Dinis, Milan Tuba, Nebojsa Bacanin
325-334
Solar Energy
Performance Assessment of Tank Fluid Purging and Night Cooling as Overheating Prevention Techniques for Photovoltaic-Thermal (PV-T) Solar Water Heating Systems
Pedro Magalhães, João Martins, António Joyce
337-347
Stochastic Optimal Operation of Concentrating Solar Power Plants Based on Conditional Value-at-Risk
João Esteves, Hugo Pousinho, Victor Mendes
348-357
Solar Thermoelectric System with Biomass Back-up
José Gonçalves, Cristina Camus, Stanimir Valtchev
358-369
Electrical Machines
A Generalized Geometric Programming Sub-problem of Transformer Design Optimization
Tamás Orosz, Tamás Nagy, Zoltán Tamus
373-381
Noise, Vibration and Harshness on a Permanent Magnet Synchronous Motor for a Remote Laboratory
Jaime Pando-Acedo, Enrique Romero-Cadaval, Consuelo Gragera-Peña, María Milanés-Montero
382-389
Levitating Bearings Using Superconductor Technology Under Smart Systems Scope
Martim Carvalho, António Arsenio, Carlos Cardeira, Paulo Costa Branco, Rui Melício
390-397
An Overview on Preisach and Jiles-Atherton Hysteresis Models for Soft Magnetic Materials
Pedro Melo, Rui Araújo
398-405
Power Electronics
Comparative Analysis of qZS-Based Bidirectional DC-DC Converter for Storage Energy Application
Oleksandr Matiushkin, Oleksandr Husev, Kostiantyn Tytelmaier, Kaspars Kroics, Oleksandr Veligorskyi, Janis Zakis
409-418
Single-Phase Wireless Power Transfer System Controlled by Magnetic Core Reactors at Transmitter and Receiver
Luis Romba, Stanimir Valtchev, Rui Melício
419-428
Soft-Switching Current-FED Flyback Converter with Natural Clamping for Low Voltage Battery Energy Storage Applications
Roman Kosenko, Dmitri Vinnikov
429-436
Electronics
Design Methodology for an All CMOS Bandgap Voltage Reference Circuit
Ricardo Madeira, Nuno Paulino
439-446
Reconfigurable Photonic Logic Architecture: An Overview
Vitor Silva, Manuel Barata, Manuela Vieira
447-462
Microneedle Based ECG – Glucose Painless MEMS Sensor with Analog Front End for Portable Devices
Miguel Teixeira, Camilo Velez, Dian Li, João Goes
463-478
Crystalline Silicon PV Module Under Effect of Shading Simulation of the Hot-Spot Condition
Ruben Anjos, Rui Melício, Victor Mendes, Hugo Pousinho
479-487
Designed by Inria-IES Team : http://hal.inria.fr/    Hosted by HAL : http://hal.archives-ouvertes.fr/
