Reconfigurable Photonic Logic Architecture: An Overview
Abstract : The photosensor studied in this document, is an amorphous silicon structure deposited on transparent glass allowing illumination on both sides. It responds to wavelengths from near infrared range to the ultra-violet. The front illumination surface is used for inputting light signal. The dynamic characteristics of the photosensor are altered by using optical bias on either surface of the sensor, thus the same input results in different outputs. Experimental studies made with the photosensor evaluate its applicability as a multiplexer, demultiplexer and logical operations device. A memory effect was observed. A programmable pattern emission system, and a validation and recovery system were built to illuminate the sensor with input light signals and to analyze the resulting output.
Document type :
Conference papers
Complete list of metadatas
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01629599
Contributor : Hal Ifip <>
Submitted on : Monday, November 6, 2017 - 3:30:15 PM
Last modification on : Tuesday, October 15, 2019 - 5:14:01 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2020-01-01
Please log in to resquest access to the document
Identifiers
Citation
Vitor Silva, Manuel Barata, Manuela Vieira. Reconfigurable Photonic Logic Architecture: An Overview. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.447-462, ⟨10.1007/978-3-319-56077-9_44⟩. ⟨hal-01629599⟩
Share
Metrics
Record views
67
