New interface
Conference papers
Levitating Bearings Using Superconductor Technology Under Smart Systems Scope
Abstract : This paper presents a study about the cooling and leakage aspects of superconductor magnetic bearings towards their integration on a smart systems scope to keep the stability of the cooling system. The use of superconductor magnetic bearings in electric power generation, namely in wind power has been increased due to their weight, friction less, and volume reduction advantages. The novelty of this paper is the use of Zero-Field Cooling instead of the common Field Cooling technique. On the other hand, this new kind of bearings needs a constant flow of liquid nitrogen to keep the superconductivity properties. A prototype was modelled, simulated and implemented for experimental validation.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-01629575
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, November 6, 2017 - 3:29:14 PM
Last modification on : Friday, August 5, 2022 - 12:39:57 PM
File
448071_1_En_38_Chapter.pdf
Identifiers
Citation
Martim V. Carvalho, António J. Arsenio, Carlos Cardeira, Paulo J. Costa Branco, Rui Melício. Levitating Bearings Using Superconductor Technology Under Smart Systems Scope. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.390-397, ⟨10.1007/978-3-319-56077-9_38⟩. ⟨hal-01629575⟩
Share
Metrics
Record views
59
Files downloads
86
