Stochastic Optimization for the Daily Joint Operation of Wind/PV and Energy Storage - Archive ouverte HAL Access content directly
Conference Papers Year : 2017
(1) , (2) , (1, 2) , (3, 1)
1
2
3
This paper deals with the problem of optimal bidding in a day-ahead market of electricity for a power producer having joint operation of wind with photovoltaic power systems and storage of energy. Uncertainty, not only on electricity market prices, but also on wind and photovoltaic powers, has to be faced in order to achieve optimal bidding. The problem is viewed as a sort of a two-stage stochastic optimization problem formulated by mix-integer linear programming. A case study with data from the Iberian Peninsula is presented and a comparison between joint and disjoint operations is discussed, allowing concluding that the joint operation attenuates the economic impact of disjoint operation volatility.
448071_1_En_27_Chapter.pdf (574.36 Ko) Télécharger le fichier
Dates and versions
hal-01629576 , version 1 (06-11-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Isaías Gomes, Hugo Pousinho, Rui Melício, Vitor Mendes. Stochastic Optimization for the Daily Joint Operation of Wind/PV and Energy Storage. 8th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), May 2017, Costa de Caparica, Portugal. pp.277-286, ⟨10.1007/978-3-319-56077-9_27⟩. ⟨hal-01629576⟩
342 View
38 Download
Share
