Using Application Ontologies for the Automatic Generation of User Interfaces for Dialog-Based Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper presents a data-centric, model driven approach for the automatic generation of user interfaces (UIs) for dialog-based applications using ontological descriptions. It focuses on Interview Applications, a common pattern e.g. for self-service applications in EIS. Existing approaches for the automatic UI generation usually rely on proprietary, UI-specific description models, designed and developed manually for the application in focus. The manual creation of the artefacts leads to a gap in the automated development, i.e. for dialog-based application UIs, where the structure and behavior is driven by the processed data. Furthermore, the UI specific nature of the artefacts impedes their (re-)use in different contexts. The presented approach is a shift away from a UI-specific towards a data-centric method of modelling dialog-based applications, bridging this gap. Application-Ontologies are used as description means, which leads to reusable, sharable model artifacts, applicable to different contexts of use.
432749_1_En_2_Chapter.pdf (1.19 Mo) Télécharger le fichier
hal-01630537 , version 1 (07-11-2017)
Paternité
Michael Hitz, Thomas Kessel. Using Application Ontologies for the Automatic Generation of User Interfaces for Dialog-Based Applications. 10th International Conference on Research and Practical Issues of Enterprise Information Systems (CONFENIS), Dec 2016, Vienna, Austria. pp.16-31, ⟨10.1007/978-3-319-49944-4_2⟩. ⟨hal-01630537⟩
107 Consultations
379 Téléchargements
