FFT extension for algebraic-group factorization algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2017
It is well known that the second stage of factoring methods that exploit smoothness of group orders can be implemented efficiently using the fast Fourier transform (FFT). For Pollard's p−1 method [17] this originated with the Mont-gomery and Silverman paper [16], and for the elliptic curve factoring method [12] it was the subject of Peter Montgomery's PhD dissertation [14]. Along with Peter's most recent work on this subject [15], these developments are presented in this chapter.
Chap8.pdf (162.23 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01630907 , version 1 (09-11-2017)
  • HAL Id : hal-01630907 , version 1
Richard P. Brent, Alexander Kruppa, Paul Zimmermann. FFT extension for algebraic-group factorization algorithms. Joppe W. Bos; Arjen K. Lenstra. Topics in Computational Number Theory Inspired by Peter L. Montgomery, Cambridge University Press, pp.189-205, 2017, 978-1-107-10935-3. ⟨hal-01630907⟩
284 Consultations
230 Téléchargements
