Pseudo-CR Convolutional FEC for MCVideo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2017
In SA4#93, SA4 has initiated the FS_FEC_MCS study item about the applicability of FEC schemes to mission critical services, in particular for MCVideo. MBMS bearer modeling has been accepted in SA#94, and evaluation procedure discussed and pre-agreed in AHI #86 and #88. In SA4#95, we presented the pCR S4-170912, which introduced a solution for MCVideo, based on a convolutional FEC. This solution was just noted, to give more time to delegates to consider this solution. Additionnally, to help the decision was required to include raptor10 within the performance evaluation, which is done in this revision.
S4-171208-was-170912 Pseudo-CR Convolutional FEC for MCVideo.pdf (715.11 Ko) Télécharger le fichier
submission_RLC_MDS-Block-Beginning_MDS-Block-During_Raptor10-Block-During.xls (55 Ko) Télécharger le fichier
hal-01632469 , version 1 (10-11-2017)
  • HAL Id : hal-01632469 , version 1
Cédric Thienot, Christophe Burdinat, Tuan Tran, Vincent Roca, Belkacem Teibi. Pseudo-CR Convolutional FEC for MCVideo. 2017. ⟨hal-01632469⟩
134 Consultations
112 Téléchargements
