Decentralized Solutions for Monitoring Large-Scale Software-Defined Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Software-Defined Networking (SDN) technologies offer the possibility to automatically and frequently reconfigure the network resources by enabling simple and flexible network programmability. One of the key challenges to address when developing a new SDN-based solution is the design of a monitoring framework that can provide frequent and consistent updates to heterogeneous management applications. To cope with the requirements of large-scale networks (i.e. large number of geographically dispersed devices), a distributed monitoring approach is required. This PhD aims at investigating decentralized solutions for resource monitoring in SDN. The research will focus on the design of monitoring entities for the collection and processing of information at different network locations and will investigate how these can efficiently share their knowledge in a distributed management environment.
385745_1_En_4_Chapter.pdf (172.03 Ko) Télécharger le fichier
hal-01632744 , version 1 (10-11-2017)
Paternité
Gioacchino Tangari, Marinos Charalambides, Daphné Tuncer, George Pavlou. Decentralized Solutions for Monitoring Large-Scale Software-Defined Networks. 10th IFIP International Conference on Autonomous Infrastructure, Management and Security (AIMS), Jun 2016, Munich, Germany. pp.47-51, ⟨10.1007/978-3-319-39814-3_4⟩. ⟨hal-01632744⟩
52 Consultations
70 Téléchargements
