Access Control for the Shuffle Index - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The shuffle index provides confidentiality guarantees for accesses to externally outsourced data. In this paper, we extend the shuffle index with support for access control, that is, for enforcing authorizations on data. Our approach bases on the use of selective encryption and on the organization of data and authorizations in two shuffle indexes. Our proposal enables owners to regulate access to their data supporting authorizations allowing different users access to different portions of the data, while at the same time guaranteeing confidentiality of access.
428203_1_En_10_Chapter.pdf (1.6 Mo) Télécharger le fichier
hal-01633667 , version 1 (13-11-2017)
Paternité
Sabrina de Capitani Di Vimercati, Sara Foresti, Stefano Paraboschi, Gerardo Pelosi, Pierangela Samarati. Access Control for the Shuffle Index. 30th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2016, Trento, Italy. pp.130-147, ⟨10.1007/978-3-319-41483-6_10⟩. ⟨hal-01633667⟩
101 Consultations
66 Téléchargements
