Reasoning About Privacy Properties of Architectures Supporting Group Authentication and Application to Biometric Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper follows a recent line of work that advocates the use of formal methods to reason about privacy properties of system architectures. We propose an extension of an existing formal framework, motivated by the need to reason about properties of architectures including group authentication functionalities. By group authentication, we mean that a user can authenticate on behalf of a group of users, thereby keeping a form of anonymity within this set. Then we show that this extended framework can be used to reason about privacy properties of a biometric system in which users are authenticated through the use of group signatures.
428203_1_En_22_Chapter.pdf (383.5 Ko) Télécharger le fichier
hal-01633672 , version 1 (13-11-2017)
Paternité
  • HAL Id : hal-01633672 , version 1
Julien Bringer, Hervé Chabanne, Daniel Le Métayer, Roch Lescuyer. Reasoning About Privacy Properties of Architectures Supporting Group Authentication and Application to Biometric Systems. 30th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2016, Trento, Italy. pp.313-327. ⟨hal-01633672⟩
451 Consultations
114 Téléchargements
