Runtime Detection of Zero-Day Vulnerability Exploits in Contemporary Software Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olgierd Pieczul
  • Fonction : Auteur
  • PersonId : 1022681
Simon N. Foley
  • Fonction : Auteur
  • PersonId : 1001643
It is argued that runtime verification techniques can be used to identify unknown application security vulnerabilities that are a consequence of unexpected execution paths in software. A methodology is proposed that can be used to build a model of expected application execution paths during the software development cycle. This model is used at runtime to detect exploitation of unknown security vulnerabilities using anomaly detection style techniques. The approach is evaluated by considering its effectiveness in identifying 19 vulnerabilities across 26 versions of Apache Struts over a 5 year period.
428203_1_En_24_Chapter.pdf (315.73 Ko) Télécharger le fichier
hal-01633685 , version 1 (13-11-2017)
Paternité
Olgierd Pieczul, Simon N. Foley. Runtime Detection of Zero-Day Vulnerability Exploits in Contemporary Software Systems. 30th IFIP Annual Conference on Data and Applications Security and Privacy (DBSec), Jul 2016, Trento, Italy. pp.347-363, ⟨10.1007/978-3-319-41483-6_24⟩. ⟨hal-01633685⟩
205 Consultations
234 Téléchargements
