Preprints, Working Papers, ...
On a Wasserstein-type distance between solutions to stochastic differential equations
Jocelyne Bion-Nadal 1 Denis Talay 2
2 TOSCA - TO Simulate and CAlibrate stochastic models
CRISAM - Inria Sophia Antipolis - Méditerranée , IECL - Institut Élie Cartan de Lorraine : UMR7502
Abstract : In this paper we introduce a Wasserstein-type distance on the set of the probability distributions of strong solutions to stochastic differential equations. This new distance is defined by restricting the set of possible coupling measures. We prove that it may also be defined by means of the value function of a stochastic control problem whose Hamilton–Jacobi– Bellman equation has a smooth solution, which allows one to deduce a priori estimates or to obtain numerical evaluations. We exhibit an optimal coupling measure and characterizes it as a weak solution to an explicit stochastic differential equation, and we finally describe procedures to approximate this optimal coupling measure. A notable application concerns the following modeling issue: given an exact diffusion model, how to select a simplified diffusion model within a class of admissible models under the constraint that the probability distribution of the exact model is preserved as much as possible?
Document type :
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01636082
Contributor : Denis Talay Connect in order to contact the contributor
Submitted on : Tuesday, June 5, 2018 - 11:05:21 AM
Last modification on : Saturday, June 25, 2022 - 7:41:01 PM
Long-term archiving on: : Thursday, September 6, 2018 - 1:50:54 PM
version-aap-j-d-R.pdf
Identifiers
  • HAL Id : hal-01636082, version 2
Citation
Jocelyne Bion-Nadal, Denis Talay. On a Wasserstein-type distance between solutions to stochastic differential equations. 2018. ⟨hal-01636082v2⟩
Share
Metrics
Record views
794
Files downloads
1142
