A coupled PDE-ODE model for bounded acceleration in macroscopic traffic flow models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
In this paper, we propose a new mathematical model accounting for the boundedness of traffic acceleration at a macroscopic scale. Our model is built on a first order macroscopic PDE model coupled with an ODE describing the trajectory of the leader of a platoon accelerating at a given constant rate. We use Wave Front Tracking techniques to construct approximate solutions to the Initial Value Problem. We present some numerical examples including the case of successive traffic signals on an arterial road and we compare the solution to our model with the solution given by the classical LWR equation in order to evaluate the impact of bounded acceleration.
Laurent-Brouty-Costeseque-Goatin-v2.pdf (858.77 Ko) Télécharger le fichier
hal-01636156 , version 1 (16-11-2017)
hal-01636156 , version 2 (09-02-2018)
hal-01636156 , version 3 (14-02-2018)
hal-01636156 , version 4 (04-07-2018)
  • HAL Id : hal-01636156 , version 2
Nicolas Laurent-Brouty, Guillaume Costeseque, Paola Goatin. A coupled PDE-ODE model for bounded acceleration in macroscopic traffic flow models. 2018. ⟨hal-01636156v2⟩
461 Consultations
354 Téléchargements
