Visualizing and Fabricating Complex Internal Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2017
Visualisation et fabrication de structures internes complexes
Additive manufacturing enables the fabrication of complex internal structures akin to foams within shapes. These fine scale structures modify the large scale properties of the shape, for instance making it lighter while preserving sufficient rigidity, or creating porosities enabling fluids to traverse. Triangle meshes are not well suited for modeling and visualizing such structures. Instead, several approaches have been proposed to model them as implicit solids, described by an indicator function returning 1 when a point lies within the solid and 0 outside. Such representations are very compact in memory, however interactive visualization and efficient processing for fabrication can become difficult. This stems from the fact that to visualize or fabricate the structure, the function must be queried at a high sampling rate. This results in a slow and memory intensive process. In this paper we discuss our approach for dealing with such complex structures in the context of interactive modeling for additive manufacturing. We describe an algorithm for the progressive rendering of the structures, as well as an efficient slicing procedure for preparing the geometries for fabrication.
RT-0493.pdf (4.82 Mo) Télécharger le fichier
hal-01636963 , version 1 (17-11-2017)
hal-01636963 , version 2 (08-03-2018)
  • HAL Id : hal-01636963 , version 1
Sylvain Lefebvre. Visualizing and Fabricating Complex Internal Structures. [Technical Report] RT-0493, Inria Nancy - Grand Est. 2017, pp.13. ⟨hal-01636963v1⟩
311 Consultations
202 Téléchargements
