Elpi: an extension language for Coq (Metaprogramming Coq in the Elpi λProlog dialect) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Enrico Tassi
Elpi is dialect of λProlog that can be used as an extension language for Coq. It lets one define commands and tactics in a high level programming language tailored to the manipulation of syntax trees containing binders and existentially quantified meta variables.
coqpl2018.pdf (527.9 Ko) Télécharger le fichier
hal-01637063 , version 1 (17-11-2017)
Paternité
  • HAL Id : hal-01637063 , version 1
Enrico Tassi. Elpi: an extension language for Coq (Metaprogramming Coq in the Elpi λProlog dialect). The Fourth International Workshop on Coq for Programming Languages, Jan 2018, Los Angeles (CA), United States. ⟨hal-01637063⟩
416 Consultations
606 Téléchargements
