Mutual Information for Quaternion Time Series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mutual Information method is a widely used method for estimation of time delay value in the process of time delay embedding. It’s designed for a univariate scalar time series. In the real systems often many outputs of investigated system are available. In this case a multivariate time delay estimation method is necessary if one may require to perform the uniform time delay embedding. The special case of multivariate data is a kinematic time series(e.g. quaternion time series or Euler angles time series). The main goal of this paper is to provide a method for this case: Mutual Information method’s extension for quaternion time series. The results are also compared with previosly presented quaternion’s angle method. The method was tested on the real kinematic data - the recordings of human gait.
419526_1_En_40_Chapter.pdf (105.74 Ko) Télécharger le fichier
hal-01637476 , version 1 (17-11-2017)
Paternité
Michał Piórek. Mutual Information for Quaternion Time Series. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.453-461, ⟨10.1007/978-3-319-45378-1_40⟩. ⟨hal-01637476⟩
55 Consultations
224 Téléchargements
