A Study on Fuzzy Cognitive Map Optimization Using Metaheuristics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Fuzzy Cognitive Maps (FCMs) are a framework based on weighted directed graphs which can be used for system modeling. The relationships between the concepts are stored in graph edges and they are expressed as real numbers from the $$[-1,1]$$ interval (called weights). Our goal was to evaluate the effectiveness of non-deterministic optimization algorithms which can calculate weight matrices (i.e. collections of all weights) of FCMs for synthetic and real-world time series data sets. The best results were reported for Differential Evolution (DE) with recombination based on 3 random individuals, as well as Particle Swarm Optimization (PSO) where each particle is guided by its neighbors and the best particle. The choice of the algorithm was not crucial for maps of size roughly up to 10 nodes, however, the difference in performance was substantial (in the orders of magnitude) for bigger matrices.
419526_1_En_51_Chapter.pdf (370.58 Ko) Télécharger le fichier
hal-01637479 , version 1 (17-11-2017)
Paternité
Aleksander Cisłak, Władysław Homenda, Agnieszka Jastrzębska. A Study on Fuzzy Cognitive Map Optimization Using Metaheuristics. 15th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Sep 2016, Vilnius, Lithuania. pp.577-588, ⟨10.1007/978-3-319-45378-1_51⟩. ⟨hal-01637479⟩
53 Consultations
79 Téléchargements
