On the Hilbert function of general fat points in $\mathbb{P}^1 \times \mathbb{P}^1$ - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
We study the bi-graded Hilbert function of ideals of general fat points with same multiplicity in $\mathbb{P}^1\times\mathbb{P}^1$. Our first tool is the multiprojective-affine-projective method introduced by the second author in previous works with A.V. Geramita and A. Gimigliano where they solved the case of double points. In this way, we compute the Hilbert function when the smallest entry of the bi-degree is at most the multiplicity of the points. Our second tool is the differential Horace method introduced by J. Alexander and A. Hirschowitz to study the Hilbert function of sets of fat points in standard projective spaces. In this way, we compute the entire bi-graded Hilbert function in the case of triple points.
FatPoints_P1xP1_arX.pdf (271.94 Ko) Télécharger le fichier
Dates and versions
hal-01637942 , version 1 (18-11-2017)
Identifiers
  • HAL Id : hal-01637942 , version 1
Cite
Enrico Carlini, Maria Virginia Catalisano, Alessandro Oneto. On the Hilbert function of general fat points in $\mathbb{P}^1 \times \mathbb{P}^1$. 2017. ⟨hal-01637942⟩
252 View
92 Download
Share
