Analysing a quality of life survey using a co-clustering model for ordinal data and some dynamic implications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Royal Statistical Society: Series C Applied Statistics Année : 2019
The dataset that motivated this work is a psychological survey on women affected by a breast tumour. Patients replied at different stages of their treatment to ques- tionnaires with answers on an ordinal scale. The questions relate to aspects of their life referred to as “dimensions”. To assist psychologists in analysing the results, it is useful to highlight the structure of the dataset. The clustering method achieves this by creating groups of individuals that are depicted by a representative of the group. From a psycho- logical position, it is also useful to observe how questions may be clustered. The simulta- neous clustering of both patients and questions is called “co-clustering”. However, placing questions in the same group when they are not related to the same dimension does not make sense from a psychological perspective. Therefore, constrained co-clustering was performed to prevent questions of different dimensions from being placed in the same column-cluster. The evolution of co-clusters over time was then investigated. The method uses a constrained Latent Block Model embedding a probability distribution for ordinal data. Parameter estimation relies on a stochastic EM algorithm associated with a Gibbs sampler, and the ICL-BIC criterion is used to select the number of co-clusters.
main.pdf (1.84 Mo) Télécharger le fichier
hal-01643910 , version 1 (21-11-2017)
hal-01643910 , version 2 (27-07-2018)
hal-01643910 , version 3 (09-12-2019)
Margot Selosse, Julien Jacques, Christophe Biernacki, Florence Cousson-Gélie. Analysing a quality of life survey using a co-clustering model for ordinal data and some dynamic implications. Journal of the Royal Statistical Society: Series C Applied Statistics, 2019, 68 (Part 5), pp.1327-1349. ⟨10.1111/rssc.12365⟩. ⟨hal-01643910v3⟩
1102 Consultations
661 Téléchargements
