Memory-aware tree partitioning on homogeneous platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Partitionnement d’arbres de tâches orienté mémoire pour les plates-formes homogènes
Scientific applications are commonly modeled as the processing of directed acyclic graphs of tasks, and for some of them, the graph takes the special form of a rooted tree. This tree expresses both the computational dependencies between tasks and their storage requirements. The problem of scheduling/traversing such a tree on a single processor to minimize its memory footprint has already been widely studied. Hence, we move to parallel processing and study how to partition the tree for a homogeneous multiprocessor platform, where each processor is equipped with its own memory. We formally state the problem of partitioning the tree into subtrees such that each subtree can be processed on a single processor and the total resulting processing time is minimized. We prove that the problem is NP-complete, and we design polynomial-time heuristics to address it. An extensive set of simulations demonstrates the usefulness of these heuristics.
RR-9115 (1).pdf (1.3 Mo) Télécharger le fichier
hal-01644352 , version 1 (22-11-2017)
hal-01644352 , version 2 (21-12-2017)
hal-01644352 , version 3 (14-09-2018)
hal-01644352 , version 4 (05-04-2019)
  • HAL Id : hal-01644352 , version 1
Changjiang Gou, Anne Benoit, Loris Marchal. Memory-aware tree partitioning on homogeneous platforms. [Research Report] RR-9115, Inria Grenoble Rhône-Alpes. 2017, pp.1-25. ⟨hal-01644352v1⟩
343 Consultations
427 Téléchargements
