Metrology in a scanning electron microscope: theoretical developments and experimental validation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Measurement Science and Technology Année : 2006
A novel approach for correcting both spatial and drift distortions that are present in scanning electron microscope (SEM) images is described. Spatial distortion removal is performed using a methodology that employs a series of in-plane rigid body motions and a generated warping function. Drift distortion removal is performed using multiple, time-spaced images to extract the time-varying relative displacement field throughout the experiment. Results from numerical simulations clearly demonstrate that the correction procedures successfully remove both spatial and drift distortions. Specifically, in the absence of intensity noise the distortion removal methods consistently give excellent results with errors on the order of +/- 0.01 pixels. Results from the rigid body motion and tensile loading experiments at 200 x indicate that, after correction for distortions, (a) the displacements have nearly random variability with a standard deviation of 0.02 pixels; (b) the measured strain fields are unbiased and in excellent agreement with previous full-field experimental data obtained with optical illumination; (c) the strain field variability is on the order of 60 microstrain in all components with a spatial resolution on the order of 25 pixels. Taken together, the analytical, computational and experimental studies clearly show that the correction procedures successfully remove both spatial and drift distortions while retaining excellent spatial resolution, confirming that the SEM-based method can be used for both micromaterial and nanomaterial characterization in either the elastic or elastic-plastic deformation regimes.
MST2006.pdf (3.48 Mo) Télécharger le fichier
hal-01644898 , version 1 (21-02-2018)
Michael A. Sutton, Ning Li, Dorian Garcia, Nicolas Cornille, Jean-José Orteu, et al.. Metrology in a scanning electron microscope: theoretical developments and experimental validation. Measurement Science and Technology, 2006, 17 (10), pp.2613-2622. ⟨10.1088/0957-0233/17/10/012⟩. ⟨hal-01644898⟩
181 Consultations
445 Téléchargements
