A protoype-based approach to object reclassification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
We investigate, in the context of functional prototype-based languages , a calculus of objects which might extend themselves upon receiving a message, a possibility referred to by Cardelli as a self-inflicted operation. We present a sound type system for this calculus which guarantees that evaluating a well-typed expression will never yield a message-not-found runtime error. The resulting calculus is an attempt towards the definition of a language combining the safety advantage of static type check with the flexibility normally found in dynamically typed languages.
jot-submitted.pdf (677.21 Ko) Télécharger le fichier
hal-01646168 , version 1 (23-11-2017)
hal-01646168 , version 2 (23-11-2017)
hal-01646168 , version 3 (06-06-2018)
hal-01646168 , version 4 (03-01-2020)
hal-01646168 , version 5 (19-01-2021)
hal-01646168 , version 6 (26-10-2021)
  • HAL Id : hal-01646168 , version 4
Alberto Ciaffaglione, Pietro Di Gianantonio, Furio Honsell, Luigi Liquori. A protoype-based approach to object reclassification: (SUBMITTED). [Research Report] Inria & Université Cote d'Azur, CNRS, I3S, Sophia Antipolis, France. 2019. ⟨hal-01646168v4⟩
480 Consultations
308 Téléchargements
