A coherent framework for learning spatiotemporal piecewise- geodesic trajectories from longitudinal manifold-valued data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This paper provides a coherent framework for studying longitudinal manifold-valued data. We introduce a Bayesian mixed-effects model which allows to estimate both a group-representative piecewise-geodesic trajectory in the Riemannian space of shape and inter-individual variability. We prove the existence of the maximum a posteriori estimate and its asymptotic consistency under reasonable assumptions. Due to the non-linearity of the proposed model, we use a stochastic version of Expectation-Maximization algorithm to estimate the model parameters. Our simulations show that our model is not noise-sensitive and succeed in explaining various paths of progression.
2017_ChevallierOudardAllassonniere.pdf (606.58 Ko) Télécharger le fichier
hal-01646298 , version 1 (23-11-2017)
hal-01646298 , version 2 (11-04-2019)
hal-01646298 , version 3 (29-05-2019)
hal-01646298 , version 4 (10-04-2020)
  • HAL Id : hal-01646298 , version 1
Juliette Chevallier, Stéphane Oudard, Stéphanie Allassonnière. A coherent framework for learning spatiotemporal piecewise- geodesic trajectories from longitudinal manifold-valued data. 2017. ⟨hal-01646298v1⟩
Collections
UPMC
1173 Consultations
342 Téléchargements
