Session Types Revisited
Session types are a formalism used to model structured communication-based programming. A binary session type describes communication by specifying the type and direction of data exchanged between two parties. When session types and session processes are added to the syntax of standard π-calculus they give rise to additional separate syntactic categories. As a consequence, when new type features are added, there is duplication of effort in the theory: the proofs of properties must be checked both on standard types and on session types. We show that session types are encodable into standard π-types, relying on linear and variant types. Besides being an expressivity result, the encoding (i) removes the above redundancies in the syntax, and (ii) the properties of session types are derived as straightforward corollaries, exploiting the corresponding properties of standard π-types. The robustness of the encoding is tested on a few extensions of session types, including subtyping, polymorphism and higher-order communications.
