Software toolkit for modeling, simulation and control of soft robots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advanced Robotics Année : 2017
Eulalie Coevoet
  • Fonction : Auteur
  • PersonId : 959400
Thor Morales Bieze
  • Fonction : Auteur
  • PersonId : 995431
Frederick Largilliere
  • Fonction : Auteur
  • PersonId : 1023855
Maxime Thieffry
Mario Sanz Lopez
Damien Marchal
Olivier Goury
Jeremie Dequidt
Christian Duriez
The technological differences between traditional robotics and soft robotics have an impact on all of the modeling tools generally in use, including direct kinematics and inverse models, Jacobians, and dynamics. Due to the lack of precise modeling and control methods for soft robots, the promising concepts of using such design for complex applications (medicine, assistance, domestic robotics...) cannot be practically implemented. This paper presents a first unified software framework dedicated to modeling, simulation and control of soft robots. The framework relies on continuum mechanics for modeling the robotic parts and boundary conditions like actuators or contacts using a unified representation based on Lagrange multipliers. It enables the digital robot to be simulated in its environment using a direct model. The model can also be inverted online using an optimization-based method which allows to control the physical robots in the task space. To demonstrate the effectiveness of the approach, we present various soft robots scenarios including ones where the robot is interacting with its environment. The software has been built on top of SOFA, an open-source framework for deformable online simulation and is available at https://project.inria.fr/softrobot/
AR_2017.pdf (1.58 Mo) Télécharger le fichier
hal-01649355 , version 1 (27-11-2017)
Eulalie Coevoet, Thor Morales Bieze, Frederick Largilliere, Zhongkai Zhang, Maxime Thieffry, et al.. Software toolkit for modeling, simulation and control of soft robots. Advanced Robotics, 2017, 31, pp.1208-1224. ⟨10.1080/01691864.2017.1395362⟩. ⟨hal-01649355⟩
532 Consultations
4974 Téléchargements
