Abstract : — This paper investigates the topology identification problem for network systems, whose subsystems are described by ODEs. In our study, the topology connections are represented as constant parameters, therefore the topology identification is equivalent to identify the unknown parameters. A sufficient condition on parameter identifiability is firstly deduced in this paper, and then a uniform differentiator with fixed-time convergence is proposed to estimate the unknown parameters.
Type de document :
Communication dans un congrès
CDC 2017 - 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia
https://hal.inria.fr/hal-01649395
Contributeur : Gang Zheng
Soumis le : lundi 27 novembre 2017 - 14:52:59
Dernière modification le : vendredi 15 février 2019 - 14:19:42
