Topology identification of network systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper investigates the topology identification problem for network systems, whose subsystems are described by ODEs. In our study, the topology connections are represented as constant parameters, therefore the topology identification is equivalent to identify the unknown parameters. A sufficient condition on parameter identifiability is firstly deduced in this paper, and then a uniform differentiator with fixed-time convergence is proposed to estimate the unknown parameters.
Automatique
Fichier non déposé
hal-01649395 , version 1 (27-11-2017)
  • HAL Id : hal-01649395 , version 1
Kokou A.A. Langueh, Gang Zheng, Thierry Floquet. Topology identification of network systems. CDC 2017 - 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. ⟨hal-01649395⟩
122 Consultations
0 Téléchargements
