Delay estimation via sliding mode for nonlinear time-delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2018
This paper deals with delay identifiability and delay estimation for a class of nonlinear time-delay systems. The theory of non-commutative rings is used to analyze the identifiability. In order to estimate the delay, a sliding mode technique and a classical Newton method are combined to show the possibility to have a local (or global) delay estimation for periodic (or aperiodic) delay signals.
Automatique
Automatica V2.pdf (257.82 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01649546 , version 1 (27-11-2017)
Gang Zheng, Andrey Polyakov, Arie Levant. Delay estimation via sliding mode for nonlinear time-delay systems. Automatica, 2018, 89, pp.266-273. ⟨10.1016/j.automatica.2017.11.033⟩. ⟨hal-01649546⟩
372 Consultations
655 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
