Practices of Disease Surveillance and Response in Burkina Faso - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stine Loft Rasmussen
  • Fonction : Auteur
  • PersonId : 1023968
Efforts to fight communicable diseases in Africa have been harmonized through the Integrated Disease Surveillance and Response (IDSR) framework. Following recent large outbreaks of SARS and Ebola further calls to strengthen disease surveillance and response, for example through information technology, are being made. To avoid parallel systems, data for IDSR is sought to be integrated into countries’ existing electronic health information systems (HIS). As experiences in this area are still limited, studying existing practices of disease surveillance and response could serve as a prerequisite for providing such electronic support for IDSR. The paper engages in this question by applying a knowing-in-practice perspective to a case of disease surveillance and response in Burkina Faso. The findings suggest that disease surveillance and response can be conceptualized as two interrelated yet distinct practices; that of surveillance and that of response. Surveillance is being both sustained and developed through everyday practices. It is also similar to routine HIS data collection, and thus seems fairly straightforward to integrate in existing HIS. Response, on the other hand, is both more complex and less sustained in everyday practice due to low frequency and unpredictability of outbreaks. Providing electronic support for IDSR should focus on maintaining a link between surveillance and response, but it would require an IS design flexible enough to also accommodate for situations that are yet unknown.
450518_1_En_28_Chapter.pdf (236.3 Ko) Télécharger le fichier
hal-01650088 , version 1 (28-11-2017)
Paternité
Stine Loft Rasmussen. Practices of Disease Surveillance and Response in Burkina Faso. 14th International Conference on Social Implications of Computers in Developing Countries (ICT4D), May 2017, Yogyakarta, Indonesia. pp.333-344, ⟨10.1007/978-3-319-59111-7_28⟩. ⟨hal-01650088⟩
117 Consultations
76 Téléchargements
