Trust Trust Me (The Additivity) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ken Mano
  • Fonction : Auteur
  • PersonId : 993540
Hideki Sakurada
  • Fonction : Auteur
  • PersonId : 1024053
Yasuyuki Tsukada
  • Fonction : Auteur
  • PersonId : 1024054
We present a mathematical formulation of a trust metric using a quality and quantity pair. Under a certain assumption, we regard trust as an additive value and define the soundness of a trust computation as not to exceed the total sum. Moreover, we point out the importance of not only soundness of each computed trust but also the stability of the trust computation procedure against changes in trust value assignment. In this setting, we define trust composition operators. We also propose a trust computation protocol and prove its soundness and stability using the operators.
450659_1_En_11_Chapter.pdf (177.17 Ko) Télécharger le fichier
hal-01651156 , version 1 (28-11-2017)
Paternité
Ken Mano, Hideki Sakurada, Yasuyuki Tsukada. Trust Trust Me (The Additivity). 11th IFIP International Conference on Trust Management (TM), Jun 2017, Gothenburg, Sweden. pp.135-151, ⟨10.1007/978-3-319-59171-1_11⟩. ⟨hal-01651156⟩
77 Consultations
67 Téléchargements
