Intrinsically Motivated Goal Exploration Processes with Automatic Curriculum Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Intrinsically motivated spontaneous exploration is a key enabler of autonomous lifelong learning in human children. It enables the discovery and acquisition of large repertoires of skills through self-generation, self-selection, self-ordering and self-experimentation of learning goals. We present an algorithmic approach called Intrinsically Motivated Goal Exploration Processes (IMGEP) to enable similar properties of autonomous learning in machines. The IMGEP architecture relies on several principles: 1) self-generation of goals, generalized as parameterized fitness functions; 2) selection of goals based on intrinsic rewards; 3) exploration with incremental goal-parameterized policy search and exploitation with a batch learning algorithm; 4) systematic reuse of information acquired when targeting a goal for improving towards other goals. We present a particularly efficient form of IMGEP, that uses a population-based policy and an object-centered modularity. We provide several implementations of this architecture and demonstrate their ability to automatically generate a learning curriculum within several experimental setups including a real humanoid robot exploring multiple spaces of goals with several hundred continuous dimensions. While no particular target goal is provided to the system, this curriculum allows the discovery of skills that act as stepping stones for learning more complex skills, e.g. nested tool use.
REWORK__Intrinsically_Motivated_Goal_Exploration_Processes_with_Automatic_Curriculum_Learning (6).pdf (2.78 Mo) Télécharger le fichier
hal-01651233 , version 1 (28-11-2017)
hal-01651233 , version 2 (24-11-2021)
hal-01651233 , version 3 (09-12-2022)
  • HAL Id : hal-01651233 , version 2
Sébastien Forestier, Rémy Portelas, Yoan Mollard, Pierre-Yves Oudeyer. Intrinsically Motivated Goal Exploration Processes with Automatic Curriculum Learning. 2021. ⟨hal-01651233v2⟩
345 Consultations
414 Téléchargements
