Abstract : Complex technical systems, industrial systems or infrastructure systems are rich of customizable features and raise high demands on quality and safety-critical aspects. To create complete, valid and reliable planning and customization process data for a product deployment, an overarching engineering process is crucial for the successful completion of a project. In this paper, we introduce a framework for process management in complex engineering projects which are subject to a large amount of constraints and make use of heterogeneous data sources. In addition, we propose solutions for the framework components and describe a proof-of-concept implementation of the framework as an extension of a well-known BPMS.
https://hal.inria.fr/hal-01651893 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, November 29, 2017 - 4:06:55 PM Last modification on : Tuesday, August 27, 2019 - 11:58:05 AM
Saimir Bala, Cristina Cabanillas, Alois Haselböck, Giray Havur, Jan Mendling, et al.. A Framework for Safety-Critical Process Management in Engineering Projects. 5th International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Dec 2015, Vienna, Austria. pp.1-27, ⟨10.1007/978-3-319-53435-0_1⟩. ⟨hal-01651893⟩
