A Framework for Safety-Critical Process Management in Engineering Projects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Saimir Bala
  • Fonction : Auteur
  • PersonId : 1024137
Alois Haselböck
  • Fonction : Auteur
  • PersonId : 1024139
Giray Havur
  • Fonction : Auteur
  • PersonId : 1024140
Jan Mendling
  • Fonction : Auteur
  • PersonId : 977590
Axel Polleres
  • Fonction : Auteur
  • PersonId : 1024141
Complex technical systems, industrial systems or infrastructure systems are rich of customizable features and raise high demands on quality and safety-critical aspects. To create complete, valid and reliable planning and customization process data for a product deployment, an overarching engineering process is crucial for the successful completion of a project. In this paper, we introduce a framework for process management in complex engineering projects which are subject to a large amount of constraints and make use of heterogeneous data sources. In addition, we propose solutions for the framework components and describe a proof-of-concept implementation of the framework as an extension of a well-known BPMS.
440701_1_En_1_Chapter.pdf (656.89 Ko) Télécharger le fichier
hal-01651893 , version 1 (29-11-2017)
Paternité
Saimir Bala, Cristina Cabanillas, Alois Haselböck, Giray Havur, Jan Mendling, et al.. A Framework for Safety-Critical Process Management in Engineering Projects. 5th International Symposium on Data-Driven Process Discovery and Analysis (SIMPDA), Dec 2015, Vienna, Austria. pp.1-27, ⟨10.1007/978-3-319-53435-0_1⟩. ⟨hal-01651893⟩
221 Consultations
130 Téléchargements
