Coherent oscillations inside a quantum manifold stabilized by dissipation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review X Année : 2018
Manipulating the state of a logical quantum bit usually comes at the expense of exposing it to decoherence. Fault-tolerant quantum computing tackles this problem by manipulating quantum information within a stable manifold of a larger Hilbert space, whose symmetries restrict the number of independent errors. The remaining errors do not affect the quantum computation and are correctable after the fact. Here we implement the autonomous stabilization of an encoding manifold spanned by Schroedinger cat states in a superconducting cavity. We show Zeno-driven coherent oscillations between these states analogous to the Rabi rotation of a qubit protected against phase-flips. Such gates are compatible with quantum error correction and hence are crucial for fault-tolerant logical qubits.
hal-01652771 , version 1 (30-11-2017)
Steven Touzard, Alexander Grimm, Zaki Leghtas, Shantanu O. Mundhada, Philip Reinhold, et al.. Coherent oscillations inside a quantum manifold stabilized by dissipation. Physical Review X, 2018, ⟨10.1103/PhysRevX.8.021005⟩. ⟨hal-01652771⟩
388 Consultations
0 Téléchargements
