Homogenised constitutive model coupling damage and debonding for reinforced concrete structures under cyclic solicitations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Solids and Structures Année : 2013
A new stress resultant constitutive model for reinforced concrete plates under cyclic solicitations is presented. This model is built by the periodic homogenisation approach using the averaging method and couples damage of concrete and periodic debonding between concrete and steel rebar. In one-dimensional situations, we derive a closed-form solution of the local problem useful to verify and set up the plate problem. The one dimensional macroscopic constitutive model involves a limited number of parameters, the sensibility of which is studied. Comparison to experimental results underlines the per-tinence of the model by considering internal debonding in order to properly represent the mechanical dissipation occurring during cyclic loadings on reinforced concrete panels.
Combescure-1D-IJSS2013.pdf (1.53 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01654802 , version 1 (04-12-2017)
Christelle Combescure, Hélène Dumontet, François Voldoire. Homogenised constitutive model coupling damage and debonding for reinforced concrete structures under cyclic solicitations. International Journal of Solids and Structures, 2013, 50 (24), pp.3861 - 3874. ⟨10.1016/j.ijsolstr.2013.07.021⟩. ⟨hal-01654802⟩
205 Consultations
76 Téléchargements
