Every entangled stuff has its own avatar - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Mario Mastriani
  • Fonction : Auteur
  • PersonId : 1034194
During the last century, entanglement was the bone of contention between the two main pillars of Physics: General Relativity (GR) and Quantum Mechanics (QM). This began in 1935 with the Einstein-Podolsky-Rosen paradox (EPR paradox) which concluded that although Quantum Mechanics is not wrong, it is an incomplete theory to represent physical reality. In this paper it is demonstrated that some byproducts resulting from entanglement, which we will call avatars, act as a hinge that link both theories making the completeness of QM clear. Moreover, a thorough analysis of the non-locality of this effect will be carried out while demonstrating that entanglement is an instantaneous phenomenon, and that it does not require the use of a superluminal signaling for this purpose. Finally, the avatars will also appear in each wormhole resulting from an entanglement process (WREP) demonstrating that they are traversable with an equivalent path of null length which can be crossed in a null time with all that this implies in Quantum Communications.
Every.pdf (3.01 Mo) Télécharger le fichier
hal-01655231 , version 1 (04-12-2017)
hal-01655231 , version 2 (17-03-2018)
hal-01655231 , version 3 (28-03-2018)
hal-01655231 , version 4 (05-10-2018)
hal-01655231 , version 5 (05-12-2018)
hal-01655231 , version 6 (26-12-2018)
hal-01655231 , version 7 (05-01-2019)
hal-01655231 , version 8 (06-03-2019)
hal-01655231 , version 9 (18-04-2019)
hal-01655231 , version 10 (17-06-2019)
hal-01655231 , version 11 (20-06-2019)
hal-01655231 , version 12 (18-07-2019)
hal-01655231 , version 13 (19-08-2019)
  • HAL Id : hal-01655231 , version 13
Mario Mastriani. Every entangled stuff has its own avatar. 2019. ⟨hal-01655231v13⟩
456 Consultations
908 Téléchargements
