Adaptive Code Refinement: A Compiler Technique and Extensions to Generate Self-Tuning Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Compiler high-level automatic optimization and parallelization techniques are well suited for some classes of simulation or signal processing applications, however they usually don't take into account domain-specific knowledge nor the possibility to change or to remove some computations to achieve " good enough " results. Differently, production simulation and signal processing codes have adaptive capabilities: they are designed to compute precise results only where it matters if the complete problem is not tractable or if computation time must be short. In this paper, we present a new way to provide adaptive capabilities to compute-intensive codes automatically. It relies on domain-specific knowledge provided through special pragmas by the programmer in the input code and on polyhedral compilation techniques to continuously regenerate at runtime a code that performs heavy computations only where it matters. We present experimental results on several applications where our strategy enables significant computation savings and speedup while maintaining a good precision, with a minimal effort from the programmer.
ACR-A-Compiler-Technique-to-Generate-Self-Tuning-Application.pdf (275.38 Ko) Télécharger le fichier
hal-01655459 , version 1 (08-01-2018)
  • HAL Id : hal-01655459 , version 1
Maxime Schmitt, Philippe Helluy, Cédric Bastoul. Adaptive Code Refinement: A Compiler Technique and Extensions to Generate Self-Tuning Applications. HiPC 2017 - 24th International Conference on High Performance Computing, Data, and Analytics, Dec 2017, Jaipur, India. pp.1-10. ⟨hal-01655459⟩
472 Consultations
267 Téléchargements
