Gesture Recognition in 3D Space Using Dimensionally Reduced Set of Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Łukasz Gadomer
  • Fonction : Auteur
  • PersonId : 1023054
Marcin Skoczylas
  • Fonction : Auteur
  • PersonId : 1024448
In this study authors present a solution to track and recognize arbitrary gestures of hands in three dimensional space and review the recognition accuracy. The idea of this novel gesture recognition system is described and results of research made on a recorded gesture data set are presented. Gesture instances were defined by user standing in different distances from the controller, in different placements of their field of vision and with different speeds, making recognition velocity and position invariant. Authors’ goal was to find the minimal number of features that give satisfying gesture classification result in order to achieve a compromise between accuracy and computation time. In this publication progress of the research on gesture recognition problem is described and a comparative study is presented.
448933_1_En_15_Chapter.pdf (1.72 Mo) Télécharger le fichier
hal-01656209 , version 1 (05-12-2017)
Paternité
Łukasz Gadomer, Marcin Skoczylas. Gesture Recognition in 3D Space Using Dimensionally Reduced Set of Features. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.167-179, ⟨10.1007/978-3-319-59105-6_15⟩. ⟨hal-01656209⟩
75 Consultations
58 Téléchargements
