Pattern Classification with Rejection Using Cellular Automata-Based Filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article we address the problem of contaminated data in pattern recognition tasks, where apart from native patterns we may have foreign ones that do not belong to any native class. We present a novel approach to image classification with foreign pattern rejection based on cellular automata. The method is based only on native patterns, so no knowledge about characteristics of foreign patterns is required at the stage of model construction. The proposed approach is evaluated in a study of handwritten digits recognition. As foreign patterns we use distorted digits. Experiments show that the proposed model classifies native patterns with a high success rate and rejects foreign patterns as well.
448933_1_En_1_Chapter.pdf (275.37 Ko) Télécharger le fichier
hal-01656223 , version 1 (05-12-2017)
Paternité
Agnieszka Jastrzebska, Rafael Toro Sluzhenko. Pattern Classification with Rejection Using Cellular Automata-Based Filtering. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.3-14, ⟨10.1007/978-3-319-59105-6_1⟩. ⟨hal-01656223⟩
105 Consultations
86 Téléchargements
