Towards Golden Rule of Capital Accumulation: A Genetic Algorithm Approach - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2017
Sankhadeep Chatterjee
  • Function : Author
  • PersonId : 1024480
Rhitaban Nag
  • Function : Author
  • PersonId : 1024481
Soumya Sen
  • Function : Author
  • PersonId : 1024482
Amitrajit Sarkar
  • Function : Author
  • PersonId : 1024483
The current study deals with maximizing consumption per worker in connection with the economic growth of society. The traditional Solow model based approach is well-studied and computationally complex. The present work proposes a Genetic Algorithm (GA) based consumption maximization in attaining the Golden rule. An objective function derived from traditional Solow model based on depreciation rate and amount of accumulated capital is utilized. The current study considered a constant output per worker to incorporate a constant efficiency level of labor. Different ranges of Depreciation rate and accumulated capital are tested to check the stability of the proposed GA based optimization process. The mean error and standard deviation in optimization process is utilized as a performance metric. The experimental results suggested that GA is very fast and is able to produce economically significant result with an average mean error 0.142% and standard deviation 0.021%.
448933_1_En_41_Chapter.pdf (771.8 Ko) Télécharger le fichier
Dates and versions
hal-01656245 , version 1 (05-12-2017)
Attribution
Identifiers
Cite
Sankhadeep Chatterjee, Rhitaban Nag, Soumya Sen, Amitrajit Sarkar. Towards Golden Rule of Capital Accumulation: A Genetic Algorithm Approach. 16th IFIP International Conference on Computer Information Systems and Industrial Management (CISIM), Jun 2017, Bialystok, Poland. pp.481-491, ⟨10.1007/978-3-319-59105-6_41⟩. ⟨hal-01656245⟩
146 View
127 Download
Share
