Efficient decoding of random errors for quantum expander codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show that quantum expander codes, a constant-rate family of quantum LDPC codes, with the quasi-linear time decoding algorithm of Leverrier, Tillich and Z\'emor can correct a constant fraction of random errors with very high probability. This is the first construction of a constant-rate quantum LDPC code with an efficient decoding algorithm that can correct a linear number of random errors with a negligible failure probability. Finding codes with these properties is also motivated by Gottesman's construction of fault tolerant schemes with constant space overhead. In order to obtain this result, we study a notion of α-percolation: for a random subset W of vertices of a given graph, we consider the size of the largest connected α-subset of W, where X is an α-subset of W if |X∩W|≥α|X|.
expander.pdf (1016.43 Ko) Télécharger le fichier
hal-01656427 , version 1 (11-12-2017)
  • HAL Id : hal-01656427 , version 1
Anthony Leverrier. Efficient decoding of random errors for quantum expander codes. Conference on ”Quantum Information Theory”, Dec 2017, Paris, France. pp.1-33. ⟨hal-01656427⟩
Collections
INRIA INRIA2
60 Consultations
75 Téléchargements
