Square on Deterministic, Alternating, and Boolean Finite Automata
We investigate the state complexity of the square operation on languages represented by deterministic, alternating, and Boolean automata. For each k such that $1 \le k \le n-2$, we describe a binary language accepted by an n-state DFA with k final states meeting the upper bound $n2^n - k2^{n-1}$ on the state complexity of its square. We show that in the case of $k=n-1$, the corresponding upper bound cannot be met. Using the DFA witness for square with $2^n$ states where half of them are final, we get the tight upper bounds on the complexity of the square operation on alternating and Boolean automata.
Informatique [cs]
