A Parametrized Analysis of Algorithms on Hierarchical Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hierarchical graphs are used in order to describe systems with a sequential composition of sub-systems. A hierarchical graph consists of a vector of subgraphs. Vertices in a subgraph may “call” other subgraphs. The reuse of subgraphs, possibly in a nested way, causes hierarchical graphs to be exponentially more succinct than equivalent flat graphs. Early research on hierarchical graphs and the computational price of their succinctness suggests that there is no strong correlation between the complexity of problems when applied to flat graphs and their complexity in the hierarchical setting. That is, the complexity in the hierarchical setting is higher, but all “jumps” in complexity up to an exponential one are exhibited, including no jumps in some problems.We continue the study of the complexity of algorithms for hierarchical graphs, with the following contributions: (1) In many applications, the subgraphs have a small, often a constant, number of exit vertices, namely vertices from which control returns to the calling subgraph. We offer a parameterized analysis of the complexity and point to problems where the complexity becomes lower when the number of exit vertices is bounded by a constant. (2) We describe a general methodology for algorithms on hierarchical graphs. The methodology is based on an iterative compression of subgraphs in a way that maintains the solution to the problems and results in subgraphs whose size depends only on the number of exit vertices, and (3) We handle labeled hierarchical graphs, where edges are labeled by letters from some alphabet, and the problems refer to the languages of the graphs.
440206_1_En_9_Chapter.pdf (415.35 Ko) Télécharger le fichier
hal-01657006 , version 1 (06-12-2017)
Paternité
Rachel Faran, Orna Kupferman. A Parametrized Analysis of Algorithms on Hierarchical Graphs. 19th International Conference on Descriptional Complexity of Formal Systems (DCFS), Jul 2017, Milano, Italy. pp.114-127, ⟨10.1007/978-3-319-60252-3_9⟩. ⟨hal-01657006⟩
28 Consultations
77 Téléchargements
