Introducing Context Awareness in Unmodified, Context-unaware Software
Software tends to be highly configurable, but most applications are hardly context aware. For example, a web browser provides many settings to configure printers and proxies, but nevertheless it is unable to dynamically adapt to a new workplace. In this paper we aim to empirically demonstrate that by dynamic and automatic reconfiguration of unmodified software we can systematically introduce context awareness. In 16 real-world applications comprising 50 million lines of code we empirically investigate which of the 2,683 run-time configuration accesses (1) already take context into account, or (2) can be manipulated at run-time to do so. The results show that context awareness can be exploited far beyond the developers' initial intentions. Our tool Elektra dynamically intercepts the run-time configuration accesses and replaces them with a context aware implementation. Users only need to specify contexts and add context sensors to make use of this potential.
Génie logiciel [cs.SE]
