New interface
Conference papers
DMOS, It's your turn !
Abstract : The DMOS method (Description and MOdification of Segmentation) is a complete system for document analysis and recognition. It is a syntactical method which enables a rule based expression of knowledge. This generic method can be applied to various kinds of documents. Its adaptation to a knew kind of document simply consists in the description of dedicated knowledge. The DMOS method has been widely validated, in several domains, and at a large scale. Now, we propose to share DMOS method for research purpose. We provide a complete environment of development in Eclipse. The use of DMOS method can help you to improve your recognition systems by combining information coming from your varied sources, being guided by explicit knowledge.
Document type :
Conference papers
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-01659131
Contributor : Aurélie Lemaitre Connect in order to contact the contributor
Submitted on : Friday, December 15, 2017 - 3:31:08 PM
Last modification on : Friday, January 7, 2022 - 3:46:47 AM
File
ICDAR_ost.pdf
Identifiers
  • HAL Id : hal-01659131, version 1
Citation
Bertrand B. Coüasnon, Aurélie Lemaitre. DMOS, It's your turn !. 1st International Workshop on Open Services and Tools for Document Analysis (ICDAR-OST), Nov 2017, Kyoto, Japan. ⟨hal-01659131⟩
Share
Metrics
Record views
206
Files downloads
160
