DMOS, It's your turn ! - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The DMOS method (Description and MOdification of Segmentation) is a complete system for document analysis and recognition. It is a syntactical method which enables a rule based expression of knowledge. This generic method can be applied to various kinds of documents. Its adaptation to a knew kind of document simply consists in the description of dedicated knowledge. The DMOS method has been widely validated, in several domains, and at a large scale. Now, we propose to share DMOS method for research purpose. We provide a complete environment of development in Eclipse. The use of DMOS method can help you to improve your recognition systems by combining information coming from your varied sources, being guided by explicit knowledge.
ICDAR_ost.pdf (524.15 Ko) Télécharger le fichier
hal-01659131 , version 1 (15-12-2017)
  • HAL Id : hal-01659131 , version 1
Bertrand B. Coüasnon, Aurélie Lemaitre. DMOS, It's your turn !. 1st International Workshop on Open Services and Tools for Document Analysis (ICDAR-OST), Nov 2017, Kyoto, Japan. ⟨hal-01659131⟩
224 Consultations
197 Téléchargements
