Asymptotic expansion for vector-valued sequences of random variables with focus on Wiener chaos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We develop the asymptotic expansion theory for vector-valued sequences (F N) N ≥1 of random variables in terms of the convergence of the Stein-Malliavin matrix associated to the sequence F N. Our approach combines the classical Fourier approach and the recent theory on Stein method and Malliavin calculus. We find the second order term of the asymptotic expansion of the density of F N and we illustrate our results by several examples. 2010 AMS Classification Numbers: 62M09, 60F05, 62H12
TudorYoshida-FIN.pdf (266.46 Ko) Télécharger le fichier
hal-01659406 , version 1 (08-12-2017)
Ciprian Tudor, Nakahiro Yoshida. Asymptotic expansion for vector-valued sequences of random variables with focus on Wiener chaos. 2017. ⟨hal-01659406⟩
84 Consultations
174 Téléchargements
