Observability analysis of linear singular time-delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper deals with the observability problem of a sort of singular systems with commensurate time-delays in the trajectory of the state, in the time derivative of the trajectory of the state (neutral terms), and in the output system. By using a recursive algorithm, sufficient conditions (easy testable) are proposed for guaranteeing the backward and the algebraic observability of the system.
Automatique
Fichier non déposé
hal-01660101 , version 1 (09-12-2017)
  • HAL Id : hal-01660101 , version 1
Francisco Javier Bejarano, Gang Zheng, Shunjie Li. Observability analysis of linear singular time-delay systems. 56th IEEE Conference on Decision and Control, Dec 2017, Melbourne, Australia. ⟨hal-01660101⟩
109 Consultations
0 Téléchargements
