Virtual Retina: A biological retina model and simulator, with contrast gain control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Neuroscience Année : 2009
We propose a new retina simulation software, called Virtual Retina, which transforms a video into spike trains. Our goal is twofold: Allow large scale simulations (up to 100,000 neurons) in reasonable processing times and keep a strong biological plausibility, taking into account implementation constraints. The underlying model includes a linear model of filtering in the Outer Plexiform Layer, a shunting feedback at the level of bipolar cells accounting for rapid contrast gain control, and a spike generation process modeling gan-glion cells. We prove the pertinence of our software by reproducing several experimental measurements from single ganglion cells such as cat X and Y cells. This software will be an evolutionary tool for neuroscientists that need realistic large-scale input spike trains in subsequent treatments, and for educational purposes.
FINAL_hal.pdf (1.56 Mo) Télécharger le fichier
hal-01660530 , version 1 (11-12-2017)
Adrien Wohrer, Pierre Kornprobst. Virtual Retina: A biological retina model and simulator, with contrast gain control. Journal of Computational Neuroscience, 2009, 26 (2), pp.219-249. ⟨10.1007/s10827-008-0108-4⟩. ⟨hal-01660530⟩
273 Consultations
310 Téléchargements
